whitrzac
Can't catch this...
whitrzac's Avatar
03.11.2009, 06:51 PM
Hey, for 40 bucks you cannot go wrong!
for 1... and I will get them eventualy, jsut like I will get a decent motor too
03.11.2009, 06:56 PM
Nothing wrong with the novak motors for 1/8 buggy use. Not the most powerful, but they are a well made motor.
As for my previous statememt I meant the motor. You can get away with the novak trays, or a cut up emaxx chassis. I like mike's trays, but do not see the need for a really heavy duty tray for a hardcase 2s lipo.
whitrzac
Can't catch this...
whitrzac's Avatar
03.11.2009, 07:12 PM
ohhh, it all makes since now.
just for fun I put it in my slash with a 9 cell gp 3300 pack
I have a slight problem though, I hit the 6.5v cutoff under "heavy"* accelaration
* I know its just the crappy batts, but I NEVER had that happen with my MM5700, or my novak 10.5
"now weres that batt adapter..."
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 08:29 AM
what do you guys think about using the savage flux battery boxes?
03.12.2009, 09:21 AM
They are designed to stand up, something like the novak trays are a better idea. A high profile box will not fit under a stock buggy body. Not much room under there.
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 09:32 AM
ok, just bouncin ideas around...
so what gearing should I start off with? I realy don't want to spend $50 on pinions...
I have a 46t spur
03.12.2009, 09:44 AM
Use BrianG's speed calc.
http://scriptasylum.com/rc_speed/_top_speed.html
Your results should look something like this:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 9
Total Voltage: 14.8
Motor KV: 5000
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 5.11 : 1
Total Ratio: 16.90598 : 1
Tire Circumference (inches): 12.57 inches (319.19 mm)
Total Motor Speed: 74000 RPM
Vehicle Speed: 52.09 mph (83.67 km/h)
An 8 tooth pinion looks like the best bet, however you may have some issues getting it to fit physically. Smaller pinions usually cause problems, as the motor can only get so close to the spur before it contacts with the diff output. The smallest hardened pinion Mike carries is a 9 tooth. I would give that a try... I usually try to gear for around 45mph, the 9 tooth will give around 50mph with that motor.
03.12.2009, 09:46 AM
Novak also make a 9t pinion that is hardened. If you plan to use a steel spur, stick with Mike's pinions as they are the best hardened pinions I have found...
03.12.2009, 09:55 AM
Linc, aren't Hyper8 tires closer to 4.25"? That can make a substantial difference.
Also, what is the deal with such a high kv? Is the goal for a fast buggy? (I don't want to read through the whole thread - I'm lazy ) Besides, a pinion that small will see faster wear. Depending on exactly how fast you want to go, I would shoot for a slightly lower kv, something around 3500-4000 and use a larger pinion - something in the 14T range.
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 12:59 PM
see post #12...
also, isn't the motor wye wound instead of delta so it would be ~a 3500kv sensorless motor?
I'f anyone is looking to trade I'm open...
03.12.2009, 01:01 PM
Yeah, that is true about the tires...
As for the motor, he can get it for 40 bucks... I would try to sell it off and make some money, and then buy something lower kv, like a medusa 60-70mm motor with kv around 2200. On 4s that can take 14-16t pinions and run in the mid 40s.
If you want to sell me that motor I will find a use for it...
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 01:12 PM
well, since I'm in the market for a new motor, what does everyone recomend? no NEUs or $150+ motors please
if nothing else I'll keep it and sell my 540 novak 10.5
the HV found its home in my slash I though at 5000kv it would be ~13.5, its closer to a 7.5
BTW that was just a mock up, I have all the wires right, and some 32p gears on it
03.12.2009, 01:16 PM
Yeah, I too would be looking in the 2000-2600kv range for 4s. Otherwise, you're gonna have a heck of a time gearing it down enough and/or use really small tires (smaller tires is like gearing down) to keep temps down.
The CC2650 motor (essentially a 1512/2.5d) would also be decent on 4s, geared around 46/14 would give you around 40-45mph speeds.
spaz163
Functionality with a dash of Form
spaz163's Avatar
03.12.2009, 01:23 PM
Don't forget about the Team Losi 8ight E battery trays as an option. They are very cheap!!
Tray
Straps for the tray
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 01:42 PM
Tray
Straps for the tray
I have the novak trys on the way here...
if I pick up a 9t pinion do you think it will be fine untill I can get a diffrent motor??
