sikeston34m
sikeston34m's Avatar
03.13.2009, 06:48 PM
Originally Posted by johnrobholmes View Post
Nice idea for the load! How big of a tub do you plan to use?
Have you decided on some standards for the testing? Temp, voltage, and capacity requirements for 1c vs stated capacity maybe?
Thanks John. I kinda like the idea myself. A tub? huh? LOL
The Hydrogen Generator that I built resides inside a 18" long stick of 4" pvc. It works best vertically. Gas rises to the top and exits through a screw in fitting to a secondary bubbler. This also "lifts" water along with it into the secondary bubbler.
Water from the secondary bubbler travels back down into the bottom of the Hydrogen Generator chamber through another tube.
In other words, as water is lifted out the top with the gas, water is replaced into the bottom. It circulates and the Hydrogen/Oxygen of course rises to the top of the bubbler. The bubbler is useful in extracting water vapor from the gas, and also helps prevent flashback to the generator in case something goes wrong.
There is some question in my mind about just how many amps this setup can maintain. I know raising the concentration of sodium hydroxide will inherently raise amp draw, BUT..........once you have so many bubbles forming on the plates it becomes a limiting factor. The bubbles begin to insulate the plates because they can't get off there quick enough. LOL
I'll have to put this to the test. Thinking back, I remember directly hooking a 4S lipo to it, and it was getting a rubber insulated 14Ga. wire REALLY hot. It would have melted the wire if I would have left it hooked up. Of course, silicone wire doesn't do this.
I would like your input concerning standards of testing. To be fair to each brand, conditions have to be controlled.
One thing that I DON'T aggree with:
In all the testing methods that I've observed, they always hook the test equipment directly to the tabs on a single cell. That's NOT where we hook our stuff.
We hook our ESC's directly to the power connector on the pack. This makes our setups work with the resistence in the wiring. Most packs "only" come with 12Ga. wire on them. At 100+ amp load, resistence in 12Ga. wire becomes a factor.
If a PACK is rated with a certain C rating, shouldn't that PACK deliver that C rating? I think so.
One thing about standards I believe, it should be the PACK tested at the connector that determines C rating.
Any thoughts or suggestions?
