lol, yeh i know what your saying but it'll cost nothing to cut my existing one in half, slide a bit of steel tube over it and weld it at the right length.
Does indeed- I like the upper deck design, definately worth going the extra mile to have a stunning home made chassis if you're capable.
Im alright, planning on taking my pet truck for a walk next week now the good weather has finally arrived, give my Medusa 36-80-2000kv a test run on 5s lipo... should be interesting...
Im looking at a medusa 80mm 1600kv now, this Neu I got cheap is a 2y 1100kv, needs something like 30v to get the most out of it. I might have to swap it after a test run.
Made some sides to stop the cells flying out and started to trim the top deck to shape.
Nice. I use the 1515/2Y with 8S lipos and it is a beast without the heat lol.
Looks really good man. But those nimh's have to go. Nimh is history. What mini lathe do you use, its looks as if it does a great job. By the way are you using 6061 or 7075?
I'm also interested in hearing about this mini-lathe. I'm really tired of making things out of tin snips and a hammer.
