03.18.2009, 08:10 PM
You generally don't want t6 charge at much higher than 2A through the balance leads as they are too small and will develop voltage drop across them making the charger's reading inaccurate. The best solution is to use a charger than charges through the main leads (which are designed for higher currents) and use a balancer to bleed off excess charge on high cells.
