Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2009, 08:47 AM
I see two things. Is the front bearing fully seated in the diff mount? i tlooks like its is not.
Also there is some wear in the output cup to the front, you can see the Pin from the cvd sitting low in the slot.. Are the outputs hardened?
The AE(and many others) simply have their bearings protruding from the bulkhead - it will fit all the vehicles mentioned so far in this thread with some shimming needed for the Ofna and older Kyosho and HB stuff(which use larger diffs). It won't drop into the MP9, which has very small diffs - would need slight mods to make it work.
The out drives are hardened - if they weren't, they probably wouldn't make it through a single race. The cvd drive pin is what is worn in Jeff's picture.
