Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
superek4
superek4's Avatar
03.29.2009, 12:55 AM
Originally Posted by MetalMan View Post
Unfortunately not, unless you do heavy modifications to the motor mount (but even then it still might not work).
so if I understood wat I m reading I can't use this diff with rc monster conversion?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
big greg
03.29.2009, 03:08 PM
you can use this diff, i run a 11t pinion on my crt with a 46t spur, with the stock crt diff mount and motor mount, the spur only sits about a 1/4 inch off the chassis. its not a big deal
superek4
superek4's Avatar
03.29.2009, 07:25 PM
thx, wats the speed r u getting? I m using a 1600kv n 2000kv medusa izzit
Ok with 4s n 6s.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
big greg
03.29.2009, 09:17 PM
Ok with 4s n 6s.
about 44 mph on 4s with a 1515 1y. you might wanna go with a 12 running the 2000 on 4s, for 6s i would gear it for the same speed and turn the epa down, its easier to switch voltages that way
superek4
superek4's Avatar
03.29.2009, 11:08 PM
hi, did u change ur gears in your front n rear diff to x2 type? Mike said need to change
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
big greg
03.30.2009, 02:08 AM
no i do not have the spiral cut gears, that just changes your ratio, you dont acually need to, just use the speed calc. youll be fine
superek4
superek4's Avatar
03.30.2009, 02:24 AM
I was told by my jamning agent that if I dun change the gear it won't be optimum.
Now my CRT is on 62spur with 14t, so if I change will be 50spur 11t pinion wo changing the F n R diff. U think better then my present setting?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
