Shark413
Shark413's Avatar
03.29.2009, 02:50 AM
Very nice Shark!!!! Did you make the for the brake servo?
I'm rnning the same gear setup now with 30K CD oil in my ST RR to help lower the motor temp.
George16, yeah I made the brake servo mount. It is a 1/8"x1" plate that sits on the chassis with a small groove cut in the end to clear the chassis lip. Then the servo mounts bolt to this plate. The plate uses the existing radio tray holes for mounting and the entire thing can be removed for servicing by removing two screws. I use 15K in the center because I need more diff action for the tight technical track I run at, it works great. I really need rear brake bias at my track to get 100% rotation around the numerous tight turns.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
