Electric Dave
03.29.2009, 09:39 PM
Thanks. I know I'm going to love the truck but the truth is, it helps to know what's wrong so you can prepare. I read these sites and found your threads particularly helpful so I figured I'd try to post the same.
I'm 75% sure I'm going to just get the +2mm hubs though my current set of wheels have already been dremmeled. I also plan on hitting the arms where the rubbing happened just to eliminate it regardless of width.
Temps were good, but I wasn't very constant about checking. My last run of the day was a very long one, 11 mins on one pack, and I had already run 3 other packs through it in a very short time. The ESC was a bit warm at about 148, no fan but warmer than I thought it would be. My next outing will be more temp focused.
My gearing was 14T pinion on the plastic 45T spur, the track was very small and I honestly feel like it may be a bit much. I was running 13/46 on my CRT last year.
