brushlessboy16
brushlessboy16's Avatar
03.29.2009, 10:43 PM
I think its time for an update. Purchased and received a secondhand Kyosho Motor mount. I the bearing holes line up fine but the upper post was .08'' too tall. a hacksaw and grinder fixed this.(avoids me buying Kyosho CD mounts). Also purchased my R1 body from jhautz- one of a dying breed- That should be here monday or tuesday. And Just now I placed a rather large order from Amain...
Wheels, tires, batts, center CVD's, Screw kit, Shock oil, and some other odds and ends.
Today I also rebuilt the entire front end with a Gene Hickerson Suspension setup
1 x AKA Racing Premium CA Tire Glue (AKA38001) = $7.69
1 x Pactra Outlaw Black Spray Paint (3oz) (PACRC250) = $5.39
1 x CEN Racing Out Drive (TR) (2) (CEGMX301) = $12.75
1 x Pactra Grape Pearl Spray Paint (3oz) (PACRC292) = $5.39
1 x CEN Racing Cross Pin, Must use with MX212 (CEGMX213) = $2.39
1 x AKA Racing City Block 1/8 Truggy Tires (Medium) (2) (AKA14102M) = $27.49
1 x Hot Bodies Rear Center Universal Shaft (Lightning Series) (HBSC8061) = $14.99
1 x Pactra Sprint White Spray Paint (3oz) (PACRC251) = $5.39
1 x JConcepts Rulux 1/8th Truck Wheel Standard Offset Half-ups (Yellow) (4) (JCI3311Y) = $18.99
1 x Hot Bodies Universal Center Shaft (130mm) (Lightning Series) (HBSC8169) = $16.99
1 x Pactra Fluorescent Race Yellow Spray Paint (PACRC284) = $5.39
2 x SMC 2S1P Hard Case Li-Poly Battery w/Dean's Connector 24C (7.4V/4100mAh) (SUM4124LD) = $129.98
1 x CEN Racing 53mm Wing Mount Post (2) (CEGMX094) = $6.79
1 x AKA Racing I-Beam 1/8 Truggy Tires (Medium) (2) (AKA14101M) = $27.49
1 x Team Losi Silicone Shock Oil (50wt) (2oz) (LOSA5227) = $3.69
1 x Team Losi Silicone Shock Oil (60wt) (2oz) (LOSA5228) = $3.69
3 x OFNA 8x10x0.3 mm shim kit (10) (OFN10413) = $3.87
1 x Tony's Screws CEN Racing Matrix TR Screw Kit (TSK-MATRIXTR) = $41.99
03.29.2009, 11:12 PM
Looks good.
Tags
cen matrix
