03.30.2009, 06:56 AM
Thats alright then. I would say if you use the same radio/ type of radio in your nitro models and it doesnt have issues, its probably the lvc cutting in occasionally which is causing you issues. Try running it with the lvc turned off, and see how it does- buy a cheap voltage checker that plugs into the lipo's balance taps to keep an eye on the cell voltages manually during the run.
Braiding the motor wires together should help reduce any glitching issues, and wrapping the rx leads in tin foil is another trick too, but you really shouldnt have any issues with a 2.4g radio.
