X1CRT has 13/43 ring and pinion gears in the front and rear diffs - same as most buggies. The x2 and most other truggies use a spiral gear set that has more reduction - this allows use of a smaller spur in the center to achieve the same or similar overall reduction (which is preferred IMO). :)
