04.03.2009, 11:51 AM
my V1 works fine
sikeston34m
sikeston34m's Avatar
04.03.2009, 11:52 AM
Originally Posted by MetalMan View Post
The MMM has a UBEC built into it as Metallover stated. If you go with an external UBEC your temps might drop by 1 deg. F, if that. Hardly worth it IMO. And the problems the MMM used to have with the BEC have been completely resolved, so the only reason I can imagine using an external BEC with the MMM is if you have a V1 or V2 MMM.
I've been running my V2 using the internal UBEC with no problems at all.
Sounds like you need to lower the gearing some.
azjc
04.03.2009, 12:00 PM
if after lowering the start setting with the ESC and its still too hot try lowering your gearing( smaller pinion, bigger spur)
MetalMan
MetalMan's Avatar
04.03.2009, 02:43 PM
my V1 works fine
Mine too
brushlessboy16
brushlessboy16's Avatar
04.03.2009, 04:24 PM
lol my v3 works fine :)
adding an external BEC doesnt fix the problem, only hides it... it may have been proven to lower temps in esc's with a linear BEC. a switching BEC creates almost no heat.. But since you have it all under control i will stop talking..
Jeremy1976
04.03.2009, 04:40 PM
I think it is crazy that he thermaled a MMM.
Joram
Nitro?? BL rulezzz
04.03.2009, 05:13 PM
haha, lol
It was not thermal shit.... Just a empty battery
But i assume it is normall then that the fan spins when the cut-off is working???
Did today some bashng with no problems, only fried AGAIN the stupid slipperpad:S
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
scarletboa
scarletboa's Avatar
04.04.2009, 12:07 AM
if your slipper is too loose, it will create more heat for both the motor and the esc. if you kept it a little tighter, it would help.
fastbaja5b
fastbaja5b's Avatar
04.04.2009, 06:20 AM
The flux slipper you have to pretty much tighten it up, even going 1/4 turn out and red loctite on the bastard it'll still come loose.
Say Less, Do More.
Joram
Nitro?? BL rulezzz
04.04.2009, 06:36 AM
You don't wanna know how i have tighten the slipper up....
It is almost inpossible how tight it is, with blue loctite on it and that helps...
But the slipper just smokes... Spur becomes hot and i have a lot power so the pads burned away, i saw smoke from the car coming
I'm now using that bycicle repair stuff, what you can cut in you own way!
It is very sturdy and i make it fully covered.
Not only as a normal pad, but also in the middel around the shaft. Just make a round one and cut the hole for the shaft...
I hope you understand this what I say
I am also working on a mountingsystem with no slipperpads, so directly the spur to the shaft...
Greetz,
Joram
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.04.2009, 10:29 AM
You'll want to keep the slipper no matter what. If you bypass it your magnet could come off the shaft in your motor on a bad landing. The slipper is there for a reason. A different pad material is probably your best solution.
04.04.2009, 11:10 AM
Riley- why have a slipper? Buggies and truggies don't have slippers, and I'm sure many other people (as well as me) have had plenty of bad landings without their magnet detaching.
Metallover
Metallover's Avatar
04.04.2009, 11:16 AM
It can happen. It is also a little more important on a mt because there is more weight and larger tires being thrown around. I guess you could go without it, but you run a much higher risk of ruining your motor. It may not happen to everybody but you may just be the lucky one...
Joram
Nitro?? BL rulezzz
04.04.2009, 12:39 PM
I think that there is an very low chance to ruin you motor with that...
Today my slipper was again the troublemaker... I'm going to screw the spurgear to the slipperhub with 3 screws, threw the spurgear. I drill the holes and use soe bolts with nuts.
I've everything on my truck bullterproof with the highest quality, but only that piece of ***slipperpad
Greetz,
Joram
azjc
04.04.2009, 12:50 PM
sounds like its time to rebuild your slipper clutch
