Originally Posted by crazyjr
You know you are hardcore if you have had and used at least 4 of those motors  2,3,5,and 7 are mine, any more than 4 is hopeless Linc
HAHA, I have owned the list save for the HC motors and bidproduct. Well, I do have the 5 of the kb45 motors, so I guess i do own a HC motor or two.
Originally Posted by emaxxnitro
well whats your list?
Well, here goes nothing:
1. Plett and Neu seem about tied. I have a feeling the plett if more powerful if you compare the actual rotor and windings, but Neu offer more options for winds and rotor length. Pletts have a nicer looking can and appear to have better quality internals, but no by much. Neu are cheaper here in the US and service is much better. I will also throw the CCNeu motor in here, as it is very nicely made, and with the limited experience I have with them, they perform very well. A diamond in the rough, IMO...
2. Lehner and the Hacker C50 lineup are about tied too. I have more experience with the C50 line, but the designs are identical, and the Hacker c50 motors are super high quality. If you prefer 2 pole over 4 pole (neu, medusa, plett) these are the motors to buy. Pricey, but what do you expect!
3. Medusa/Aveox. Medusa - Can't beat the price, and the QC seems good. I have a few motors, and only had an issue with one. It may have been a lemon, but I did not test enough to get a feel for it. The other motors have performed very well. Not as good as a Neu, but similar. Aveox - Steve Neu worked for aveox, so the motors are very similar. 36mm diamter, and use std threads so kinda weird. Great power, slightly less than a neu of the same length/spec, but I think they are more powerful than a medusa. Hard to find new, so not much point talking about them.
4. Hacker B50. Good motors, but not much better than the Feigaos that are basically clones. Better materials make them more efficient, run cooler. Not worth what Hacker charges for them, but if you get a deal on a used one go for it. 2 pole motors, so they will work with just about any esc.
5. Feigao. Honestly these are not that bad. Sure the magnets let go at higher rpms and they run hot. Ok, so maybe they are not that good, but compared to the even cheaper HC kd motors they are pretty good. Considering the price of a medusa, there is not much point buying these new. The vxl motor fits in here to. All are 2 pole.
6. KB45 L and Xl. Big motors, 30mm m4 bolt pattern, and 6mm shafts. Great deal for the money, and if you can turn the shaft down, or use the small selection of 6mm bore pinions, they will easily outperform any motor that costs even twice as much. They do not run all that hot in any application you would use a 1515 or an xl.
The rest of the motors listed are low end and should be avoided. Not sure about the Losi motor. Not many have tried it and compared it to a neu. Too expensive, IMO.
