SYLVERIS
SYLVERIS's Avatar
04.09.2009, 04:41 PM
Hi, lincpimp,
I have send you some pictures of this motor here :
http://sylveris.free.fr/Serie2.html
Link works now...
I know why bearing are out now, and why they don't want to send us an other bearing !!!
The problem is a clearness now : It's due to the bended shim which is mounted on the shaft to prevent wearing ( play ) , and I think there is a conflicting with this shim and this type of bearing. Some users and me can find a little play on the bearing but just in case : when you push the shaft, you can find side by side wear ( play ) ! "When you push on the shaft", but behind there are the shims and one of it lean on the bearing... Is it not to hard for the bearing ? I think this type of bearing is not made to have some weight apply on it like this ?
I have order a pack of tapers M2.5x0.45 for blind holes and I will try to drill myself 4 holes for the unscrewing like losi motors. My front cover wasn't tighten enough and I have turn it 45° more, 1/8 turn !!! Then because I have to drill an other hole, I will do 4 ones, and put 4 screws to retain the front cover. I think I will find too, some little shims to take out the bended hole and to search myself the right wear ( play) to keep between the gold shims and the bearings, and of course new high speed bearings.
Just look at this link and don't forget this was the last year !!!! :
http://www.rcgroups.com/forums/showthread.php?t=837325
There are some questions about the bearings...and steve Neu explain that they have problems with bearing quality, but this was last year, and many people say that there's again many problems...
