TomTomTuning
04.09.2009, 09:29 PM
Originally Posted by squeeforever View Post
I could go on for a while on other hopups, but Mikes diffs, Tekno sway bars, Traxxas tubes (front turnbuckles and pushrods), one good servo, RPM arms and True-Trac, and the RPM knuckles in the front are a good place to start.
Sweet,
I'll start with the Lipos, RPM arms and True-trac. Then maybe swaybars and wheel bar.
The car came with the Traxxas tubes, but i snapped one when i broke the upper A-Arm....
I was looking to ordering another set of TRX rods and i notice they had a P1/P2 then a P3. Whats the P3? (longer?)
So far ive just been running it in the grassy area by my work, i need to find a better place to really bring out the beast in this thing.
squeeforever
squeeforever's Avatar
04.09.2009, 09:40 PM
Originally Posted by TomTomTuning View Post
Sweet,
I'll start with the Lipos, RPM arms and True-trac. And go from there. Maybe the swaybars after that.
P3 is just a different rocker. I, along with 99% of Revo owners run the P2 rockers. They use the LT/P1 pushrod, but require the little red spacers that are included.
TomTomTuning
04.09.2009, 10:30 PM
I was about to ask more about the LT, P1, P2 and P3 rockers... haha
But i found this site. (explains alot of the suspensions components)
http://monster.traxxas.com/showthrea...suspension+faq
I didn't see anything about the red spacers.
-1- Is that to extend the pushrod and make the clearance a little higher?
-2- Do you have your pushrod in the middle, inner or outer hole on the A-Arm?
I might try putting the LT stiffer springs (Silver/blue) on the p2 rockers..
I hate when the car dips so much it smacks the floor.
I guess the red Aluminum pushrods i have 5318X only work with LT and P1 rockers...
So i'll be taking them all off when i put the P2 Rockers on.
PS: Appreciate all the help. This is my first off-road/truck. Ive always had AWD Sedans.. haha
