Tekin 1/8 Scale controller release date?
TekinTeamMgr
04.10.2009, 01:18 PM
The unit does not come with presoldered connections. Care MUST be taken to get good solder joints on this unit!
The fan takes about 30 seconds to replace! It has an easy to use connector and only 4 screws and then slides out the top.
I also recomend leaving it out while you solder on your wires of choice.
TekinTeamMgr
Find all posts by TekinTeamMgr
Hybrid Mode
Switch to Threaded Mode
Off
