Always Dreamin
04.12.2009, 09:54 PM
Originally Posted by scarletboa View Post
i am on a tight budget and i put a nice sized dent into my vxl's motor after jumping 20ft+ in the air. the shocks are all toast and won't hold oil any more, so it smacked the ground pretty hard.
would this motor be enough to push my rustler vxl around on 3s lipo? would it run too hot?
ammo 36-40 3900kv motor
it is the same width as the vxl motor but it is also 16mm shorter. the vxl motor is a 36x56 and the ammo is a 36x40.
i know performance won't be the same but on 3s, i'm sure it'll still be insane. i only ran cheap tenergy ni-mh batteries anyway with the vxl.
Do you still have the vxl esc? if so, you can just buy a sensor cable and run a 5.5r or other novak motor. they are pretty high quality and shouldn't heat up too much. A forum member (takedown) ran a setup with the 5.5r and got a 80 mph Rustler. If not a Novak, look into maybe a used vxl? or send yours in?
