04.13.2009, 10:45 PM
Well, it's done!
I ended up ditching the front drive and totally re-doing the layout. This allowed for much better weight balance - now the center is only about 5mm off center! Aside from the batteries, all the other components are as far right as I could make them.
Total parts list and other points of interest (taken from my BL Conversions page because I'm lazy):
  • Spektrum DX3r Radio
  • Mamba Max ESC with the BEC disabled
  • Dimension Engineering ParkBEC
  • Medusa 36-50-3300 motor with added heatsinks
  • Elite 3s 30C 3300mAh lipo battery
  • Geared 45T spur, 15T to 26T pinion depending on desired speed
  • Modified the chassis around the spur gear to allow easier gear changes
  • Custom 6061-T6 aluminum motor mount
  • Custom 6061-T6 aluminum top plate
  • Custom 6061-T6 aluminum battery tray with lexan shield for the bottom of the battery
  • Custom 1.5mm thick aluminum shield under the rear differential to protect against rocks
  • Servo mounts from an Xray XT8 to mount the steering servo
  • Front toe links from an Xray XT8 for the steering linkage
  • Rear wing stay from a Mugen MBX5r for one of the top plate standoffs, the rest are custom cut 6061-T6 aluminum tubes
  • Turnbuckle from the Traxxas Jato for a chassis brace
  • Converted to 2WD to allow better placement and balance.
  • Upgraded to Traxxas steel outdrives
  • Upgraged to Traxxas aluminum rear axle carriers
  • Moved steering assembly to the other side for more even balance
  • Moved rear shock mounts to the same bolt as the body mount to allow for more ground clearance.
  • Removed first gear and modified the two speed hub to be locked into second gear to enable motor braking and reverse
Anyway, here are the pics:
This last one just showing the weight balance. I don't have a scale, so a thin piece of wood will have to suffice.
