jholthus
04.14.2009, 12:54 AM
Well seeing as how I did not have a stock emaxx to play with, and I built mine from the ground up(as Niel said, not legos), I just came to the conclusion that FLM can't cater to everyone's taste and just mounted the receiver. If you look between the two servos you can see it. Or if it really bothers you, you can make a mounting plate out of CF or something either behind the tranny or make it go above the servos so you can mount it. Just an idea, since that's what we are talking about.
