04.16.2009, 02:35 PM
thanks. My battery is 165mm and I just wanted to make sure it will fit. not sure about the diff. Really want to see if mikes slipperential will fit. If not I would like to try a losi smartdiff. I know they make down to a 43t for that.
Have fun with the buggy and let us know how it holds up. I will be waiting for mine.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
04.16.2009, 02:46 PM
Nice! Can you measure the distance from the face of the motor mount to the radio box?
04.16.2009, 03:17 PM
is the ratio on this buggy like the RC8, 4.3? if not, what is it?
THE Paranoid Android
04.16.2009, 03:27 PM
80mm exactly - though there will be no room for motor wires.
There is a 43T crown gear and 11T pinion - so 3.909...
I don't think you would be able to use a smart diff either - it's not the spur gear size that's the problem, it's more that the diffs are so short - the entire centre diff (spur gear to diff case bottom) is only 18-19mm long!
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
04.16.2009, 03:54 PM
Thanks for the info.
"Out of spec" enthusiast
04.16.2009, 06:27 PM
I haven't seen a body for this buggy. It must be pretty thin given no mudguards. Is there a body/any pics?
04.16.2009, 07:19 PM
here is a shot with a body. Taken from the ebay auction.
04.16.2009, 08:42 PM
Nice specs, looks like they used a hyper 12 center diff, means there might be a plastic option for the >5 class cars
04.17.2009, 07:06 AM
The body is just the nitro one, disappointingly. I was expecting something far narrower - so I'm going to make side guards or an undertray out of lexan, otherwise my electrics won't stay clean for very long. Hopefully some aftermarket manufacturer will come up with a 'proper' electric one.
04.17.2009, 07:36 AM
Very cool! That's the first Hyper 9 I've seen converted
04.17.2009, 09:07 AM
its not a conversion, its the production Hyper 9E that we will ge over here in the USA soon.
What is the smallest pinion you think will fit with the stock spur gear?
Kind of sucks they didn't do a better fitting body or at least include mudguard setup.
Can't catch this...
04.17.2009, 09:14 AM
you will send this to me
looks nice though...
04.17.2009, 02:03 PM
Unfortunately not
I reckon an 11 or 12 T on the safe side. I'm using a 15T, which appears to be spot on with the speed calculator. It could easily go closer, so you could even maybe get a 10 or even a 9T on there.
Originally Posted by gizzer
Hyper 9e, 6s, tekin rx8 1400kv (all coming soon)
So you like it then!
04.17.2009, 06:06 PM
Yes I like it. I want it. I ordered it. I am impatiently waiting for it.
As a side note. Nitrohouse now updated there site. says expected 4/22  . Now my tekin system better be here when the buggy arrives. Lhs back ordered the buggy awhile ago so I should be able to get one on the first shipment.
oh and its gixxer, as in the suzuki(gsxr) motorcycle. the way you wrote it, I am not really sure.
04.17.2009, 06:29 PM
gixxer is when you own some GSXR's, gizzer is for when your to old to own GSXR's.
