Thread Tools Rating: Thread Rating: 9 votes, 4.11 average. Display Modes
lutach
lutach's Avatar
04.16.2009, 07:08 PM
Sometime in the near future i will be participating in an intership program at Lockheed Martin
Let me know when....They have a lot of nice surplus things that will be good to use.
brushlessboy16
brushlessboy16's Avatar
04.16.2009, 07:11 PM
I already called dibs
We(myself and partner in crime Eovnu87435ds) both got selcted for the internship program due to our background in electrical systems. Pretty sure we get to work with the AEGIS system and the Radar testing equipment... Robotics does have its perks
lutach
lutach's Avatar
04.16.2009, 07:13 PM
I think the right motors for 1/5 scale are the big Neu 22xx, Plettenberg Bolido and the Lehner 36xx. I also think Astro Flight has some low Kv big inrunners too and when the appropriate ESC comes out they should be a good motor too (Actually they are really low Kv and might not work).
brushlessboy16
04.17.2009, 09:26 AM
I like the looks of the bolido, but do you know where I can get more info on it? Its neat that its a direct fit for an fg pinion which is also mod1.5 and makes life easier
04.17.2009, 10:34 AM
Here you go http://www.icare-rc.com/plettenberg_pricelist.htm#cars
good luck on that, its a tad spendy
Fast5sRevo88
04.17.2009, 03:02 PM
Is there a target price for the conversion kit?
Byte
05.22.2009, 04:30 AM
Lol, it's funny that this brushless motor costs 100 dollar less in the EU. Mostly all things are cheaper in the US than in Europe..
lutach
lutach's Avatar
04.17.2009, 03:46 PM
Harold pointed out the place to get the motor and the pinion can be found at https://sdp-si.com/eStore/, click on metric go to spur gears and use the drop down boxes to select the following: 1.5, With Hub & set screw and the bore size.
04.17.2009, 04:31 PM
Gotta watch them... I ordered 8mm bore 1.5mod 12t pinions for my baja and selected w/hub and setscrew and they showed up without any setscrews, or the drilled/tapped holes that a setscrew would go into... Good thing I have a drill press...
lutach
lutach's Avatar
04.17.2009, 06:09 PM
Good to know, but it hasn't happened to me yet. Thanks for the heads up. Did you get the carbon steel ones?
