Joey
The Big Cheese
Joey's Avatar
04.16.2009, 08:33 PM
what do you want to run? I'd go atleast 6s in a heavy savage. You can run a larger spur and smaller pinions. Lowering speed will lessen the load and increase efficiency (not really efficiency, but it'll run longer) In general, higher voltage means less amperage.
p.s. 35-40k rpm is good for neu's and medusa's
over 35k rpm with a feigao equals burnt
castle motors seem to spin forever
All I want is to keep the amps/heat down and get about 50mph max. 45 max would even be great. I guess I could get a bigger spur, that does seem like the smartest thing to do!
But would keeping the batteries and gearing the same while dropping motor to 1300kv increase efficiency (or reduce heat/amperage) or decrease it due to running at lower RPM compared to the 1500kv?
04.16.2009, 09:25 PM
the above rpm numbers put the motors at their greatest efficiency. I can't exactly tell you specifically what you are asking, but a good basic rule is to turn your motor at 35k rpm with whatever voltage you have.
I would run atleast 6s in a savage, so get whatever motor that spins at 35k rpm on 22.2 volts
