did anyone tried this?
the hw combo for 6s... I would like to test but look likes this will make the motor spin at almost 50k rpm...I little scary for an hw motor...maybe I'll stay at 4s...
cheers
Are you referring to the huge 45mm diameter HW motor? 2000kV at 6s is only 44.4krpm...not too bad. The 2350kV 36mm motor would be over 52krpm, which is too high, but I think the 45mm 2000kV motor would work fine on 6s.
