04.17.2009, 08:29 PM
I'm not paying more than the minimum and I get wayy better than that. Even if testing off your wireless laptop, I would expect much faster than that, unless the signal strength to your access point was really weak. If you can try hooking a CAT5 cable from the laptop to the router/access point (or even directly to the cable modem).
-real pc idiot here- I'm hooked to my modem with an ethernet cable, is that cat5?
