Can size?
Hockeyplaya20
Hockeyplaya20's Avatar
Can size? - 04.19.2009, 12:37 PM
What size is the can for the MMM 2200kv?
I was wondering if it would fit in my rustler? (Yeah, im crazy :))
6s MMM E-Revo l Rustler VXL l Stampede XL-5
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.19.2009, 12:41 PM
It is about 44mm diameter I believe. It'll fit with a FLM tranny case
Hockeyplaya20
04.19.2009, 12:48 PM
is that because of the tranny's rear end? if so, i dremmeled that off
brushlessboy16
brushlessboy16's Avatar
04.19.2009, 03:22 PM
its because of the entire left (looking at the back of the truck) casing where it covers some of the motor.. a 2200 will not fit under without an flm transmission case as stated above or major modification
You are pretty limited to 36mm diameter motors... if you have the cash look into the 14 series neu which is has the same internals as the 15xx, but in a smaller can.
2200 is wayy too much for a rustler on any voltage, a medusa 60 would move it just as well and be less weight.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.19.2009, 05:53 PM
Your such a downer... If he wants to blow up some Rustler diff gears like the rest of us do, I say more POWER to him!
Hockeyplaya20
04.19.2009, 08:23 PM
EXACTLY! lol
im going to do it :)
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.19.2009, 09:14 PM
Ok well if your gonna you better run it on 6s 10,000mah and mount the battery in the front, using it as a bumper. That's gonna be your only hope at keeping the front end on the ground.
Hockeyplaya20
04.19.2009, 10:20 PM
hahaha! u mean 6s, 5000mah?
Hockeyplaya20
04.19.2009, 10:21 PM
i can easily beat 80 mph, right?
brushlessboy16
04.19.2009, 09:30 PM
Do what Rc-Driver Did to test the Bl revo on 6s. Duct taped a 2lb Iron weight to the fro of the truck.
You better make sure your tires are glued well and you have plenty of spare trannies lying around
What's_nitro?
04.19.2009, 10:23 PM
What tires are you running? Anything under 3.5" and it will not wheelie- trust me. Speed Hawgs are good, or Panther slicks. As far as top speed- how much room do you have?
Hockeyplaya20
04.19.2009, 10:31 PM
im doing this for shits and giggles :D
i may actually go somewhere and do a speed run
im running talons, ill need new tires :)
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.19.2009, 10:32 PM
Yes I meant 6s 10,000mah!!! Your going to need a brick on the front of it to keep the front down! Tires under 3.5" don't mean squat, it's still gonna wheelie. A 1515 motor on the back is a lot of weight that is going to help any tire get traction. My friend was using 2.2 dirt hawgs with a 4600kv sidewinder combo and all that did was wheelie only running a 2s MA pack
What's_nitro?
04.19.2009, 10:34 PM
1: Those tires are too tall.
2: The suspension was too soft.
3: The battery didn't provide enough front weight.
Hockeyplaya20
04.19.2009, 10:42 PM
i thought
series, with 2 3s 5000mah it is 6s 5000mah
parallel, with 2 3s 5000mah it is 3s 10,000mah
well my talons, basically have no grip :)
