crt .5 center diff needed
crt .5 center diff needed - 04.21.2009, 05:11 PM
I can't find one. I need it for my ls10. Anybody?
04.21.2009, 06:46 PM
Harold, I found the gears if this helps....http://www.amainhobbies.com/product_...ducts_id/13418
04.21.2009, 07:01 PM
Thanks. If somebody won't sell me one I'll have to piece it together. somebody has one they want to sell me.......
04.21.2009, 08:01 PM
Harold, do you need a case as well? I may have one
04.21.2009, 08:17 PM
I need the case and internals and spur. Basically the whole center diff (less mounts) Cups and bearings too.
What's ofna's new equivalent to the crt .5? Maybe somebody's chopping them on e-bay?
edit: it's the ofna hyper mini st
04.21.2009, 08:25 PM
Will the f/r case fit in the middle?
04.21.2009, 08:40 PM
where's LincolnPimple when you need him?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.22.2009, 08:15 AM
The front cases are the same as the middle. I posted on another thread...
rootar
rootar's Avatar
04.22.2009, 11:20 AM
check ebay for awhile im sure one will pop up before too long, i picked one up for $25 when i put one in my ls10
04.22.2009, 11:26 AM
You do realize that the bearings are different than normal 8th scale CDs right? IIRC, they are 1mm smaller in diameter than a normal CD if that makes any difference.
04.22.2009, 01:36 PM
yeah, ls10 is 10th scale. I modded an mgt spur to the ls10's slipper and had to lock it tight. I'm just thinking my drivetrain will thank me for a center diff. E-bay isn't helping. Somebody throw an outrunner in your crt .5 and sell me the center diff!!
04.22.2009, 02:50 PM
I am right here... No crt.5 stuff though. Dork.
04.22.2009, 02:54 PM
ah, i figured you had 7 or 8 .5's laying around. What's with the sweet talk? Did I miss our anniversary?
04.22.2009, 03:13 PM
Offer someone a suitable outrunner (and the stuff to make it hook up) and you might have better luck.
04.22.2009, 09:33 PM
Harold, I have a case and gasket if this helps...let me know
