04.21.2009, 07:06 PM
Originally Posted by littlegiant View Post
Will a KB45L 2300KV motor overheat on 4S lipo in a 4.3Kg e-savage? Assume that it is geared for slightly over 40mph (around 25T)
I have one new kb45 motor but I am not sure if I should just get a HW150A for use with it or should I get a MMM/CC Neu combo.
It should be alright, but watch temps closely. I'd get the MMM to run the kb, and upgrade to a cc neu if the kb fails.
littlegiant
05.16.2009, 03:43 PM
Some pictures of my KB45 L can 2300KV
The rotor looks pretty well made.
The shaft has been ground down to 5mm.
ID:	7003   Click image for larger version
ID:	7004   Click image for larger version
scarletboa
scarletboa's Avatar
05.16.2009, 04:29 PM
how did you grind down the shaft?
littlegiant
05.16.2009, 05:23 PM
Ran the motor while filing it.
scarletboa
scarletboa's Avatar
05.16.2009, 05:38 PM
did you grind a flat spot on the shaft?
littlegiant
05.16.2009, 10:00 PM
Not yet.
sikeston34m
sikeston34m's Avatar
09.17.2009, 12:05 AM
Did you simply unscrew the front endbell?
How tough was that?
