04.21.2009, 10:40 PM
no. the 2s and 3s must be the same mah and c cells, from the same manufacturer. series adapter, yes. does not matter what side is which.
the setup you describe would "work" but the two batteries will have completely different characteristics and not work well together. Also, if you are parallel or series wiring batteries you want them to be the same age with the same amount of cycles on them.
