will this buggy diff fit.
bazz
will this buggy diff fit. - 12.17.2005, 09:02 AM
i am wondering if a kyosho gigacrusher dual engine diff fit in any 1/8 diff cases for the emaxx, they are helical cut gears and are supposed to be quite strong. can handle dual 26 motors with the greatest of ease. any thoughts or anybody who knows if they fit would be great.
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.17.2005, 01:22 PM
No idea without picture's/ measurement's. I'm pretty sure it is somewhat bigger than the emaxx diff's. Might need 1/8 diff cases.
  Send a message via MSN to Sneeck
bazz
12.18.2005, 08:46 AM
the measurements are as follows, crown wheel is 38mm round, with bearings on it is 34mm from outside of bearing to outside, from outside of diff case to outside of crownwheel 23mm , diff case is 30.5 mm round, from outdrive to ouydrive is63mm to 63.5mm, bearing is 16mm round, i am awhere i need 1/8 cases but i dont have any to try if they fit. any help would be sweet.
coolhandcountry
coolhandcountry's Avatar
12.18.2005, 10:06 AM
The measure ment you gave does not match up to the measurements that the 1/8 buggy diffs are. I am not saying it won't work but It seems smaller.
Peace!
Country
Help support the
Rc-Monster
Buy here
