View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
hemiblas
hemiblas's Avatar
04.23.2009, 07:42 AM
When I hook up my watt meter and turn the switch off the amp load is 0. Are you guys sure the ESC drains the battery with the switch off? Now switch on, it does measure a very small load enough to drain the battery. There has been a couple times when I take a tumble and the switch turns off. Made me a bit worried on my V3, but then I just check it and turn the switch on and everything is good again.
