whitrzac
Can't catch this...
whitrzac's Avatar
04.24.2009, 11:20 PM
low 30s....would be a good starting point. are you gonna run it on 3s or 4s? you could prolly run one GOOD 3s 5000 25c pack and mount the motor on the other side with a custom flm style mount and make it lightweight and then you cold prolly gear it for 35 safely and have decent temps.
I only have 2s batts, so 4s
this motor doesn't need to last more than a month or soo... its just till I can get an RX8 combo
I'm kinda geting conflicting arguments here, one says that its a ton more power than stock, but then you say to gear it for 30?? is it just a heat issue? or is it underpowerd??
2 540 size heatsinks and some thermal past cost <$10...
or am I better off buying a $30 dewalt motor?
