lutach
lutach's Avatar
04.25.2009, 09:26 AM
Well, first of all, what is your LVC point? If it's set kinda high, you won't be taking the full 4800mAh out of it anyway, so it makes sense you won't put 4800mAh back in. And anyway, the difference between 115A and 120A is not worth worrying about because A) you are only pulling that in bursts, and B) it's only a ~4% change. Over time, capacity is gonna drop; that's just age. Worry if you get to the point where you're only putting in ~4000-4200mAh with a proper LVC setting.
Awesome explanation Brian. You should add this and other related info in a sticky (I'm not sure if there's one already).
