SV6000
SV6000's Avatar
04.27.2009, 11:06 AM
There are some companies out there making aluminum wheels i think mike stocks some. You could also try the traxxas 17mm hexes and rims, they have an extra cut out on the drive hex that is mirrored on the rim to spread the load over more surface area. Or you could try making your truck lighter after the pull off. The two lipos will help with that alot.
Tags
aluminum wheels
