MetalMan
MetalMan's Avatar
04.29.2009, 11:21 AM
You could shoot RC-Monster Mike (the owner) an email, it's likely he has the drawings for what you need already. Your mount would be the same as for the Mammoth ST, XLB, and XT2, except it would need to be optimized for the 53t spur gear.
Also, you may want to reconsider your setup. That gearing on that motor will be quite stressful on the motor (50+mph), and typically the 2650 is used for buggies. You would be much better off with the 2200 and a 14-15 tooth pinion.
And welcome to RC-Monster!
