Chase023
Chase023's Avatar
03.08.2005, 02:22 AM
I don't think the 9918 is designed to handle 4 Pole motors which are a bit harder on controllers. I believe the 9918 is designed to handle up to 18 cells but not a Maxximum or a BigMaxximum. I could be wrong but I think the 4 pole motor is too much for it to be reliable.
Well I was really never worried about the weight because I wanted just raw power for this project and didn't care about handling just wanted power but now that I weighed 60 cells, its like 7+ lbs LOL.. Tho I would go Lipo which I would need 10 Cells per motor so I would need 20 Lipo cells but the config I need doesn't fit, unless I can get a custom designed lipo batteries. I asked Thunder Power batteries about it many times but no luck. The dimensions I have to work with is about as long as a normal 6 cell stick pack so I could theoretically lay down 15 cell per level which would line up 5 cells per column and 3 cell rows.
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
