Originally Posted by Always Dreamin
That sounds right.... do the front tires balloon up big when you gas it? Probably not anything stripped as you said it sounded normal..... could be tires slipping, but i think you'd notice the loss of traction.
usually when the front tires are spinning, you can tell because it's hard to control. just wants to go in a straight line.
you hit the nail on the head. i couldn't tell the front was ballooning on the 8ight i was using because i was using those new thick rubber tires from losi that don't balloon until you hit 100mph. (new losi rally tires)
here's a pic:
so i put the stock tires back on and tried it again. the front tires got so big i thought they were gonna blow off the rim. the rear stayed normal sized.
he said running 6S geared as big as i was with a motor the size i was on 7K diff fluid using was why it was slipping so bad. it was over-powering the center diff.
He suggested trying 30K, so i'm gonna give that a go. Thanks for the advise everyone, much appreciated.
