the body i chose for my .5
Doug Shelp
the body i chose for my .5 - 05.04.2009, 01:57 AM
im useing a proline crowd pleaser on my rcm ,all you have to do is trim it up normaly as if you were gona instal it on a stock .5. then you install an 1/8 truggyrear body mount on the front of the rear shock tower cut the mount holes in the front of the body a bit more forward.i also made a reinforcment for the rear mount out of lexan card stock and shoe goode it in and for the sides i made a1/2 in. aluminum angle iron bracket so i could atatch the body on the sides with velcro witch make this body rock solid.OFNA has asked proline to make up a run of the .5 crowd pleaser and there avvailable now and to me with the tires and wheels ive put together and the RCM conversion this thing looks like an 1/8 truggy
nougat
05.08.2009, 12:19 AM
I had success with an Associated RC10T4 body. All I had to do was cut a notch for for the wing stay. It's a little short in the back, but I like the look. This is my first paint job, so I kept it real simple.
Loving my brushless crt.5! I've learned a lot from lurking on this forum and this is my setup:
  • RC-Monster extended chassis and conversion kit
  • Mamba Max ESC
  • Traxxas VXL Velineon Motor 15T pinion on 2S for track and 3S for bashing (tried Medusa 36-50-4800kv... great motor, but I didn't think it was worth the extra $$$)
  • Revo Hard Anodized GTR front shocks with 1.4 Jato pistons and 1.6 Jato blue springs 30wt shock oil (OFNA DM-1s were big improvement over stock, but not enough travel)
  • OFNA big bore front buggy shocks in the rear with 50wt oil and soft springs
  • Lunsford titanium turnbuckles and hingpins, including 4x23mm upper arm turnbuckle with beefier rod ends (if only I could get a beefier upper arm).
  • OFNA CNC alloy knuckles, c-hubs and rear uprights
  • 2.2 truck Gladiators (pictures), Bowties and Holeshots on HPI Scorch wheels
  • 1/10 scale truggy wing
05.08.2009, 06:59 PM
  • Mamba Max ESC
Looks very nice!
