stampy
stampy's Avatar
12.20.2005, 06:53 PM
the rs4mt is a truck. and i cant switch it back cause the small pulley im using is aluminum and it slightly wider than stock, so i cant fit 2 of them on the shaft. ive had a bl setup in the truck already, although it was slow caused my pos battery's, it still was fast enough to show that traction wasn't much of an issue. plus the way the truck is made and the weight is setup in it, its less likely to flip over when driven hard
