Go Back   RC-Monster Forums > Support Forums > Team Tekin
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
05.07.2009, 08:04 PM
I think thats a mistake and the 2000kv is a 2D. The neu 2D motors have slightly less kv than the neu 1y motors, which is how I can tell.
The advantage of y winds is that you can vary the timing for positive results, which you can't do with d winds and wye winds are supposedly slightly more effcient than d winds. For obvious reasons, d winds allow for more kv options, but someone please tell me if there really is a powerband difference between y and d? Comparing a y vs. d of similar kv, does one have more bottom end or more midrange power?
Also, for those of you who have had tried both y and d winds, its only fair if they are of the same motor series. Feigao motors are sure to have a different powerband from these tekin and neu motors not because they are delta or wye wound, but because feigaos are slottless and tekin/neu are slotted.
Area 52 Ranch Raceway
T.R.C.R.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.07.2009, 08:06 PM
If I had to guess I'd say "D" stands for delta and "Y" stands for.. star?
It would be just how the winds are hooked up.
SpEEdyBL
SpEEdyBL's Avatar
05.07.2009, 08:19 PM
Thats right. both types have current going through two coil phases in series, but d winds also have current going through the third coil, in parallel with the other two coils.
T.R.C.R.
