You get it a FMAdirect.com . Yes, it has the revlectrics brand on it too.
To charge two 5000mah 4s packs at the full 5 amps at the same time, you would probably want to pick up a 15amp ower supply. If you are just doing one at a time you can just get a 10 amp power supply.
to make it...
or break it...
