What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.09.2009, 10:45 PM
If you want to run it at the 7.4V buy a CCBEC and hook up it's output to the servo power leads only, then use the castle link to set the output to 7.4V. That way your servo sees 7.4 and the rest of the system runs off of the MMM BEC. You would only plug the servo's signal lead into the RX.
