SpeedAssault
SpeedAssault's Avatar
05.16.2009, 11:27 AM
Originally Posted by squeeforever View Post
Yea, he was definately wrong.
The only somewhat confusing part of all of it is parallel. 2 3S 3000mah packs in parallel will be 3S 6000mah, like pimp said, but it would still be 30C. Differance is, the amps double as well, just not the C. Its pretty simple one you think about it. A 3S 3000mah 30C pack is 90 amps, but a 3S 6000mah 30C pack is 180. Still 30C, but when the MAH is doubled, so is the amperage since C x Ah = amps. Got it?
Thank u squee,
Wow , thank you for putting it into that example, it makes more sense and easy to folow.
But that is weird to figure, that MAH double and amps double but not the C rating. I thought the C rating had to do with the amp output..?
So what importance is C rating, how is it used ?
How about in series, whats that equation ?
I may want to use two 3s in series
thank you for your help, it really
