I'm using Mike's motor mount in my Jammin Truggy. I love it however, with the freakin ferris wheel of a spur gear(62T) I can only mesh a 18T pinion yielding not so favorable numbers for now.... only 73mph. I was going to try 22/88 on 6s first which should have yielded about 85mph.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 62
Pinion Tooth Count: 18
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0.1
Motor Current Draw: 75
Motor coil Ω: 0.006
Spur/Pinion Ratio: 3.44 : 1
Total Ratio: 11.39316 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 47850 RPM
Vehicle Speed: 72.47 mph (116.41 km/h)
Effective KV Value: 2155.41
KT constant: 0.61 oz-in/A
Motor Torque: 0.24 ft-lbs
Final Torque: 2.74 ft-lbs
Final Power: 1665 watts (2.2 HP)
However, I do have an extra center diff from my Jammin buggy(48T). So I will probably swap that in place and run 18/48 20/48 and then 22/48 on some speed attempts...
Just made a couple quick passes with the Jammin, geared 18/48 with 13/43 diffs on 5s. This thing is insane and a torque monster. I don't know how to keep the front end down and the front tires from ballooning insanely! Unfortunatly I lost the damn pinion gear, so I'll be forced to run either the 20T or 22T next. Honestly I'm kinda scared to.
Thinking about putting some thicker diff fluid, or locking silicone in the CD. Thinking this will increase wheelies but kill some of the unloading. I can dial out the wheelies with punch control settings.
That's crazy fast, man.... I like it! It reminds me of my Rustler- Any increase beyond 30% throttle is like "auto tire-spin" mode, and it isn't just hitting the end of the punch control. Isn't excessive power fun?
I can't keep the damn pinion on. Lost it twice more, luckily I found it both times. I made a couple passes on 5s at 22/48 and its insane. I'll make a couple more passes and throw the GPS on it. I doubt I get any video, no one to video for me.
