Go Back   RC-Monster Forums > Support Forums > Team Tekin
lutach
lutach's Avatar
05.16.2009, 09:27 PM
If things are not working the way they are supposed to, why not check everything over instead of trying to make it work? If something cogs or doesn't move, that means something is wrong and just trying to give it more throttle would just make it fail. Maybe something shorted some where. This thread would also be better in Tekin's page so Team Tekin can see it right away and help you with this problem.
05.16.2009, 09:49 PM
...This thread would also be better in Tekin's page so Team Tekin can see it right away and help you with this problem.
Good point. Thread moved.
XXXDAD
XXXDAD's Avatar
05.17.2009, 12:20 AM
Brand new here,,, thank you!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
RUSTY XL-5
RUSTY XL-5's Avatar
I had a similar issue with a mm. LOTS of cogging, no throttle etc. Turned out to be a loose motor wire solder connection. Fixed it, and mm runs like it did before.
I will spank a nitro any day...guaranteed. :)
XXXDAD
XXXDAD's Avatar
Angry 05.17.2009, 12:19 AM
Had it together for 2 min, then it went bad... was checking things out with the batt. conected and the switch off.. then the smoke started. I am very capable... just not happy not sure what happend...
all the settings were tripple checked before even turning the esc on... i'm a a loss for words....
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
05.17.2009, 11:30 PM
Went for a test... had just turned it on after tripple checking everything... it was sitting on my lap with the Batt. pluged in and the switch OFF..... Went up in smoke in my lap..... was set to brushless, 4 cell, all low values, ... did the claibration and I'm experenced... So Mon. I send it next day with hopes of getting it back for the end of the month! I have Tekin in two other cars. I love there product and Tekin has great customer service.. ! I have no dought they will come through for me! It's my Birthday weekend and it's for the Jconceps weekend here in Coral Springs Florida!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
lutach
lutach's Avatar
05.18.2009, 09:33 AM
Originally Posted by XXXDAD View Post
hooked it up , would not go.. pushed it went , then stoped .. Click Click Click...... then shut it off at the switch.
I used to go to the track in Coral Springs when I used to live there and I also went a lot on the track in West Boca.
Maybe it's just one of those units that might have a faulty components somewhere.
Now for Tekin, why have a brushed setting on the RX8? Keep it brushless only. On the R1/RS that setting would be good since it's small and if there's anyone out there still running brushed in a race they can use it and later upgrade to a brushless, but it doesn't make sense in the RX8.
05.18.2009, 09:55 AM
...Now for Tekin, why have a brushed setting on the RX8? Keep it brushless only. On the R1/RS that setting would be good since it's small and if there's anyone out there still running brushed in a race they can use it and later upgrade to a brushless, but it doesn't make sense in the RX8.
I say, "Why not?". All that is required is a tweak to firmware, so there aren't any extra components needed. And it creates yet another selling point (even though it may never be used). I'm sure some of it is marketing and some is just offering features comparable to the competition. Might be useful for special projects where you want to hook up several medium-power brushed motors to one ESC...
lutach
lutach's Avatar
05.18.2009, 10:05 AM
Tekin made a racing system for 8th scale brushless racing and one that brought back a 4 pole sensored motor which is already a selling point. As for marketing, they would be better by stating a higher AMP rating like many do, but Tekin is better then those other guys, so the brushed setting on the RX8 does nothing for the product. The R1/RS Pro could pretty well handle those several medium-power brushed motors if a project needs it. I see more and more people just using brushless and don't get why a brushed setting in a brushless ESC is needed. Tekin already has brushed ESC on the market. Now I don't know how much space on the software a brushed mode takes, but it could be space for other option that could improve on the brushless side.
