Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
Diff blocks
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
Diff blocks - 05.18.2009, 10:45 PM
The diffs move in a Revo. They move inside the bulkheads. Just look at the abrasion marks on your diff cases and inside the bulkheads when you take them apart. Some people tried to stuff silicon in there to hold the diffs in place, some put foam underneath the chassis to press down on the diff. I'm sure someone will chime in with yet another Band Aid fix for this little problem. I want a permanent fix. I am going to try out these diff blocks that key into the bulkheads and sandwich the diffs in place holding them tight preventing movement up and down, left and right. I made them for my LST2 diffs but I'm sure they would not work for the stock diffs.
The front blocks
And the rear blocks
No brain, no headaches.
