Alright my buddy and I finally got down to business and ordered the rest of the stuff we need, and spent a few hours making the battery trays.
These are "the goods" :) 9920/8xl, 14 gp3300 cells, and 14 IB3800 cells.
These are the battery trays we made. Note, mine are not quite finished as they are not plasti-dipped yet, nor have I decided where to mount the brace (hence the reason there is just a peice of cut aluminum resting atop the trays).
These are my buddies trays that have already been dipped, and his tray-brace that got dipped as well.
This is the way I was Wanting to mount everything. Having the rx batt under one of the trays on the chassis (only running rx batt till I get home from the trip and order a motor clamp and Ubec). Mounting the receiver against the motor plate (Plan to rig up a box somehow to mount against the plate, so the receiver is not directly against the plate). and then have the controller mounted on top of the tray-brace.
The problem is with this mounting setup ^^ The controller wires will not reach the back of the motor :( I really hate to add any length to those wires, as I know the longer the wires get, the more inefficiency (plus it would look hacked with some black/red wire added onto the ends of the nice wire already on the controller!)
So... I thought maybe this mounting setup might work??
This puts the RX batt across the top of the trays on the tray-brace, and then the controller would get tucked under the tray. (either mounted against the tray, or against the chassis)
I like this setup as it protects the controller, and then the wires will reach to the motor. The only things that concern me with this setup, are A: Heat build up. I plan to run bodies all the time, so airflow will already be cut down, thus not being much of an issue? and B: Can the heatsink short out the controller if it touches bare metal? I will have my trays plasti-dipped as soon as I figure out the final layout, but was worried with it being that close to the chassis.
For those who have dealt with similar setups, does the 9920 get warm in a setup like this? (9920/8xl geared relatively conservatively on 14 3800's/ 14 3300's)
If I ran this setup ^^ I do have two small 3/4 inch fans I could mount to the top of the controller without much problem, but would prefer not to if avoidable, mostly because of the fact this truck will be run primarliy on the beach in florida for the next two weeks.
I apologize for the crappy picture quality. I have a new 7.2 mp sd550 camera coming in about 3 days, so wont have to deal with this ancient 1.3 mp camera anymore!
Any input is greatly appreciated!
