05.21.2009, 04:02 PM
Best to remove the red wire from the signal plug and run an external bec/ rx pack when using any more than 2s lipo. The linear bec in the quark will get quite warm with anything over 2s lipo, as it has to bleed off the addl voltage over 6v as heat...
Quark makes a great esc as far as software goes. I have 2 125b and 2 65 roadsters. I have had great use out of them, although they are a bit iffy on 6s. Work fine on 5s!
