You can charge thru the balance taps, but not over 1 amp as the wires are a bit thin. Just find the 2 wires, pos and neg that go to that cell, use a multi meter to figure that out. Ten either use a female tap with wires to attach to the charger or unplug the 2 wires from the tap and use alligator clips, be careful not to touch them together.
