I try to keep all my motors below 160, normally more like 150. ESC should be fine below 180. If yours is getting that hot something is wrong though because the fan should keep it under 160. I try to keep my lipos under 120, if I see 120 at the shrinkwrap I give them a few minutes to cool off because the cell temp will be hotter than that.
Uhh Sully, the fan kicks in at 150F and beyond that I think the thermal protection kicks in.
IIRC the fan comes on at 140. If you're getting much more than 160 than the fan is either damaged or not capable of handling the heat. If it can't handle the heat you're most likely pulling WAY too many amps.
