HighKalibre
05.23.2009, 01:10 AM
I was originally running running 25/56 gearing on 5s. At about 3/4 throttle it hits 60mph. Thats with a very gradual throttle curve, 3/4 throttle was roughly 60% power.
When I was doing my speed runs there was still a lot of sand and gravel on the roads from winter time. it got pretty hairy and I crashed er a couple times.
I was also running 100% punch control.
Anyway heres some finished shots of it:
It wouldn't win any beauty pageants, that was a lot to pack onto that teensy weensy chassis
I thought keeping the side covers closed would be an issue at first but I found a work around for it. Drilled 2 holes in each cover for 4mm screws and drilled and tapped the top for 4mm. o-rings to secure.
Oh also came up with a 5min mod that I thought worked rather well
There was always talk of the front end lifting up during high speeds so I give you my front wing:
Used an old rear wing I had sitting around stock front bumper attachment. Drilled 2 holes in the wing 2 screws to finish
